New cam is in my car and new dyno #s are 405 rwhp and 380 rwt. Still has a very good idle. New PCM should be installed next week. Goal is 415 rwhp or 488 at the crank. The parts and package will be available at DRM's web site soon.
01 Z06-- Quicksilver, modified torch red interior, DRM long tube headers, cam, CNC heads, 11.4 to 1 compression ratio, Donaldson LS6, Corsa Indys, Euro tail lights, B&M Ripper
405 rwhp, 380 rwt Minneapolis,Mn
Ron M.
Trumper, no knocking so far. We are running premium pump gas. We will be experimenting with the exhaust next. What makes more hp, Corsa or stock titanium?
Ron M.
We are still fine tuning. With our weather, the car will be snow bound until probably April. Car should be done and dynoed before then though. /ubb/smilies/biggrin.gif
Ron M.
Difficulties/lessons learned with clutch replacement on the Z06.
This is a supplement to the online instructions how to do this.
Do not try to do this from jack stands your cussing vocabulary will increase tremendously if you try. Do it on a lift preferably a two post lift.
It helps a lot if...
I had a "Check Engine" light come on over the weekend and I knew there was a way to get the code with the DIC. I checked the manual with no luck so I called the guys at DRM. Tim is great to help me with any questions I have and he sent me the following directions. I thought some of you might...
Looking to purchase a second set of wheels so I can swap out street vs AutoX tires, but I'm uncertain how the clearance / fitment will work with C6 Z06 brake assembly. Can I still run C5 Z06 OEM? Do I move to C6 Z06 OEM? Other?
Current wheels are CCW C10s, front and rear both 18".....have...
1. I get a code of C1242, "BPMV pump motor ground open circuit' and 2. when pulling key from my ignition switch, my driver's seat goes to the ease of exit position. However, when unlocking with fob and putting key in ignition, the driver's seat does not return to the previous setting. Could it...
We’re a forum community dedicated to the Chevy Z06 Corvette. Come check out discussions on performance, specifications, modifications, purchasing, maintenance and more!
