1 - 1 of 1 Posts
My clutch pedal return spring broke (or a least half of it did) and I need to replace it. It still basically works, but if the other part goes, then I'm in trouble. It's the spring you can see looking up under the dash, and the spring mounts right to the arm of the clutch pedal. p/n?
Next - I have taken the center console/arm rest out a couple of times now, and I broke the connector for the fuel door release. The wiring harness and it's connector are fine, but the "socket" portion of the connector that is mounted under the console is broken. Anyone know the p/n?
Thanks!! :crazy:
1 - 1 of 1 Posts
