1 - 2 of 2 Posts
Anyone!
I have been told by a good friend that the abs module is located under the passenger seat, can I be so lucky? Is this correct, if not where is it located? I was told that this is a much talked aobut problem due to condensation inside of the module. Is this something fairly easy to replace, do I need to take it to the dealer?
-Troy
The ABS Hydraulic Control Module and ABS Modulators are located on the left frame rail in front of the power steering pump.
I also understand that the Traction Control, Active Handling, ELectronic Brake Control Module, and Electronic Brake Proportioning Controller are all located within the BCM (Body Control Module). The BCM is located in the front right passenger kick panel floor board, just under the dash.
1 - 2 of 2 Posts
