Active Handling is acting up. In the DIC I am getting a message "active handling warming up" and I have the active handling yellow car in the speedo area. I was just wondering if this was normal.
thanks,
mike. :D
Does the message go away after awhile? I've seen that before on mine after starting the car. If I remember correctly, the manual states that it is normal.
As long as the message goes away...it's normal!
Charlie
From other posts on this subject, the system on start up must program it self & needs to have the car go in a straight line for 20 feet or so. Thus if you have steering inputs right after start up before you move the car in a straight line you may get that message. 100% normal.
if you do a search you will find a lot of info
Now that's something I definitely did not know.
It is true that you learn something new everyday. :z:
