I just purchased a set of BAer +2 Rear Rotors (2-piece) for the Z and someone told me this:
Is this gonna be an issue for daily driving?
I dont intend to track the car but if I do, I'll swap the rotors w/ factory/NAPA ones.
I hope that the fronts are +2 as well... otherwise the ABS is going to be working overtime and the car would be very unstable braking for corners.
I would definitely say that +2 with the stock calipers is for looks only. I can see that the increased torque arm of a +1 on stock calipers is a fair upgrade, but if you are going +2 you probably need more pad area. Those brakes are just going to overheat and fade during track use.
