I agree. The subframe pins don't have much play in them... but it doesn't take much to change your alignment either. Your toe could easily be off by 1/16-1/8". This isn't a huge change, and probably isn't even enough for the vast majority of drivers to notice, but it may negatively impact your tire wear. :cheers:IT L GO said:IMO it's a very good idea. Those pins have enough play in them to throw the alignment off. :cheers:
No problem. Glad it helped you.tratr said:Thanks for the responses. Haven't made up my mind yet. Thanks for the tutorial Dope, you made the job much easier.
Thanks, I appreciate the support.tratr said:Thanks for the responses. Haven't made up my mind yet. Thanks for the tutorial Dope, you made the job much easier. Brad, I made my order and received it just in time to throw everything back together. The pump is on backorder though.
