I have a 2002 "Z" that I want to have aligned. My son has a 1999 FRC that also needs aligning. The problem is I can not find a shop that anyone has used and will recommend it. Would like to have some suggestions from anyone in the area for a reliable shop. Thanks for the help.
Gene :thumb:
May want to call Doug Rippie Motorsports for alignment specs... they do awesome street/track setups. Don't know about the shops in your area.
Any alignment shop that has been around for a time should be able to do the job . Todays alignment machines are computerized so anyone that can read the monitor and turn a wrench should be able to set the alignment to stock specs . The computer has all the numbers all they have to do is turn the wrench till the numbers match. All this being said if you are going racing then you will need some one with talent and knowledge. I personally use a shop that's been in operation for the past twenty five years :cheers: :cheers:
