1 - 10 of 10 Posts
Are alignment specs the same for the '02 as for the '01?
Anyone happen to have them handy?
Frank and JC, can we include these in the Owner FAQ section?
Thanks...
G
Front Individual Caster +6.9 +/-0.5
Front Cross caster Within +/- 0.5
Front Individual Camber -0.70 +/- 0.5
Front Cross Camber within +/- 0.5
Rear Individual Camber -0.68 +/- 0.5
Rear Cross Camber within +/- 0.5
This is what I believe this is the alignment for the zo6 specs set up....I think they are 2001.
Don't know if they changed..for 2002
:-? Does anyone know if 01/02 have the same specs for the alignment needed after you have lowered the Z :-? Please let me know :D :cheers: :cheers: Farris :z:
Discussion Starter · #9 ·
Z06 Wheel Alignment Specifications
Front Alignment Specs Service Allowable Service Preferred
Front Individual Toe +0.14 to -0.06 degrees +0.04 degrees
Front Sum Toe +0.28 to -0.12 " +0.08 "
Front Individual Camber +0.50 to -0.70 " -0.20 "
Front Cross Camber +/- 0.25 " within 0.50 "
Front Individual Caster +6.4 to +7.4 " 6.9 "
Front Cross Caster +/- 0.25 " within 0.50 "
Steering Wheel Angle +1.0 to -1.0 " 0.00 "
Rear Alignment Specs Service Allowable Service Preferred
Rear Individual Toe +0.09 to -0.11 degrees -0.01 degrees
Rear Sum Toe +0.18 to -0.22 " -0.02 "
Rear Thrust Angle +0.10 to - 0.10 " 0.00 "
Rear Individual Camber +0.32 to -0.68 " -0.18 "
Rear Cross Camber -- within 0.50 "
:cheers: :guiness: :) :D :eek: :roll: :puke: ;) :guiness: :cheers:
:eek:
:eek:
:D :cheers: :cheers: NOW U Z ME thanks alot man now I can get mine done. If you need my help on anything just give me a SHOUT :D :cheers: :cheers: Farris :z:
1 - 10 of 10 Posts
