A small percentage of the initial production run (@5%) did have an oil control ring problem that when driven constantly in and over 3500 RPM would cause "ring flutter". This would happen especially if the engine was abused during break in (first 1,000 miles).
Chevy subsequently fixed most of those cars under Warranty and reengineered the oil control ring on later production run '01's and subsequent years.
In addition a small percentage of '01 and subsequent year production cars also had a precieved or actual oil consumption problem because of the newly designed PCV system. This was caused by a faulty or incomplete Valley Seal.
To determine if a particular car had an oil consumption problem an Oil Consumption Test (OCT) was performed. If this test showed excessive oil consumption the proceedure was to replace the Valley Seal first, and do another OCT to differentiate the problem if it still exsisted.
NOTE: All LS1's & LS6's, F & Y bodies will experience higher oil consumption if the car is used in competition...as will most any other engine. The LS6's PCV empties into the intake manifold behind the Throttle Body. Under High RPM competition
this oil will be injested and burnt in the combustion cycle. This may be interpretted as undue oil consumption, as evidenced by a blackened exhaust reside, but it is not. This is normal. To avoid this a "catch can" can be installed in the PCV system.
If you own an '01 or are contemplating purchasing one then a number of things are in order.
1. Ascertain when your car was produced and more importantly when the engine was produced.
2. Ascertain if it is using oil at an increased rate.
3. Have an OCT test done to verify if it is or is not.
(You can do this your self by performing an oil & filter change and filling with a normal 6.5 qt. fill. Note the mileage and drive normally for 1,000 miles. Perform another oil change and measure the oil drained out and subtract from the oil installed (6.5 qts) originally. (Note: you should let the engine drain for 1 Hour for accuracy) .
4. Check for oil behind the Throttle Body (drops on the Manifold floor) after driving normally for this 1,000 miles. If there is oil after driving normally then you will need to investigate the Valley Seal. If there is oil after hard competition it is normal, if not excessive.
5. If the car has had an OCT or has not shown high oil consumption and is a later '01 production or subsequent year then it is probably a safe bet.
6. If a later production run '01 or an '02 or subsequent year has an oil consumption problem (and they can) then it is most probably the Valley Seal.
There was an early racers fix for LS1's that allowed the oil control ring to reseat by using straight weight Kendall 30W non synthetic, for 1,000 miles and changing 3 times over 3,000 miles. Then switching back to Mobil 1 Synthetic. However this was a temporary fix as a the rings would still reenter "ring flutter" if abused. I do not recommend this but it may be appropriate for a dedicated race car or one that is out of warranty. Note: that some racers use the Kendall non synthetic exclusively but are changing oil after each race and are rebuilding the engine annually anyway.
NOTE: all higher mileage cars/engines and abused engines will show higher that normal oil consumption no matter what type of oil control ring they have or what make of car they are.
NOT ALL '01's had an oil consumption problem, ONLY a few did. Most of those have now been repaired.
Most all of the '01's are a good value and a good buy.
This statement does not reflect the opinion of Z06vette.com or any of it's members or Chevrolet or General Motors Corporation
