All,
The below info shows a slightly modified printout from the AMSOIL Online Product Application Guide for a 2003 Z06.
(The links have been modified to take you to my website to view the product information.)
This guide shows exactly which AMSOIL products are available for almost every vehicle made in the last 25 years.
Information on ordering AMSOIL at retail can be found here:
AMSOIL Ordering Information
AMSOIL Preferred Customers save about 20%:
AMSOIL Preferred Customer Program
2003 CHEVROLET CORVETTE 5.7L 8-cyl VIN Code S
FILTERS
Oil Filter......EAO32
Oil Filter......WIX 51042
Air Filter......EAA83
Air Filter......WIX 46144
Fuel Filter......WIX 37737
BOSCH WIPER BLADES
Driver side......B40922
Passenger side...... B40922
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
AMSOIL Series 2000 0w30
AMSOIL SAE Synthetic 5w30
Above 0°F......10W-30[1]
AMSOIL SAE Synthetic 10w30
All Temps......5W-30[2]
Manual Transmission,.....AF3
AMSOIL ATF
Controlled Slip Differential, Rear .....GL-5*[3][4]
75W-90
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
AMSOIL Slip-Lock Differential Additive
Fluids
Power Steering Fluid.....PS
Power Steering Fluid - Not Available Through Amsoil
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3 - Not Available Through Amsoil
Clutch Fluid.....HB
1. Oil must meet GM specification 4718M.
2. SAE 5W-30 is preferred.
3. CS IDENTIFICATION: tag under cover-ataching bolt. Models
with limited slip use 4 oz of GM part no. 1052358
additive or equivalent when fluid is changed.
4. Synthetic oil is required.
CAPACITIES
Engine, with filter..........6.5 quarts[1]
Cooling System, Initial Fill..........13.0 quarts
Automatic Transmission, 4L60E Initial Fill..........5.0 quarts[2]
Automatic Transmission, Total Fill
4 speed 4L60E..........11.0 quarts
Manual Transmission, 6-spd..........8.0 pints
Differential, Rear..........3.4 pints
1. Capacity shown includes filter. after refill check oil level
TORQUES
Oil Drain Plug.....18 ft-lbs
Manual Transmission
Fill Plug.....20 ft-lbs
Drain Plug.....20 ft-lbs
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
FILTERS
BOSCH WIPER BLADES
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
AMSOIL ATF
75W-90
Fluids
Brake Fluid.....HB
Clutch Fluid.....HB
CAPACITIES
TORQUES
Manual Transmission
SERVICE INTERVAL
