AMSOIL recently released two formulations of high performance brake fluid:
AMSOIL Series 500 High Performance DOT 3 Brake Fluid
AMSOIL Series 600 DOT 4 Racing Brake Fluid
AMSOIL Series 500 High-Performance DOT 3 Brake Fluid has a dry ERBP of 525°F and wet ERBP of 313°F, which far exceeds DOT 3 requirements of 401F (dry) and 284F (wet). The Series 500 DOT 3 Brake Fluid is recommended by AMSOIL for C5 and C6 Z06s. If my car was a daily driver (and/or under warranty), I'd use this fluid. I do intend on ordering a case for all my other daily drivers.
AMSOIL Series 600 DOT 4 Racing Brake Fluid has a dry ERBP of 580°F and wet ERBP of 410°F, which compares very favorably to other racing brake fluids such as ATE Super Blue which is 536F (dry) and 388F (wet). I will order a case of this and use it in my track use only 2002 C5 Z06 this season.
Thanks for the info Brad....I'll add a container to my next order for sure.
Just in time for the new brakes on the RS project.
