I just installed my PCV catch can and wanted to make sure it was connected correctly. The instructions were not Corvette specific. Maybe those who have installed one before can verify my installation.
The yelow line is the tube coming from the intake valley into the top of the catch can. The green line is coming off the throttle body going into the lower port on the catch can. The purple line is the the inline PCV valve. Note the direction the PCV is installed. Does this look right? I wanted to make sure it was right before driving it.
Thanks!
Your plumbing looks correct to me, it's like mine. Although your pic is bright, there's too much black color for me to distinguish the direction of your PCV. If you have installed it backward, in about 100 miles it will throw a code "check engine light". If that happens clear the code and turn the PCV around.
Chas.
