Hello everyone.
I have a bit of a problem and am not sure what the cause of it might be. So here is the problem. Once in a while the motor will idle up to 2,000 RPM's, or so, and stay there for a few seconds. Then it will fall to 4-500, RPM's, or so, and back up again. It is getting worse and I have not clue as to what the cause might be. The intake system is a Halltech cold air and the bored throttle body. So, has anyone had this problem before? As for the history on this motor. It is an oil burner, valve pinging, and yes I use 92 octane gas, valve rattling and surging piece of S$#T. I would appreciate any available info.
Sincerely,
Justin C.
Sincerely,
Justin C.
