1 - 20 of 64 Posts
I built the engine today:
Balancer Marked before removal:
Front Cover Removed:
Old cam out and New cam going in:
Degreeing the cam :
Oil pump mod parts:
New Balancer and front cover installed:
Head gaskets before head install:
Engine assembled:
Read from the beginning here-
http://www.z06vette.com/forums/showthread.php?t=83571
I should be putting in the car over the next couple weeks.
:jammin:
Great pics Andy. Keep em coming. :thumb:
There is something very pornographic about inserting a new lubed up camshaft. :blush: :crazy:
Looking good Andy. Did you tank your block or anything. It looks new. I have some discoloration on some of my aluminum parts and would like to clean them up. What do you recommend? You made a cam change. Do you have the old vs new spec's. Why did you switch?
D.J.
Clean parts!
I clean all the aluminum parts with the same acid and water that we use on the subframe parts.The engine came from my 2001 Zo6 that only had 10,000 miles and was not a daily driver,I also clean under the hood way more than you should.
That is why it is so clean.
The cam change was my decision based on life of the valve springs.The other cam was very high lift for a street car.It is the same cam Lpe runs in most 2005 LS2 HC cars.
I am not looking for a race car(as stated before).This one will be a true driver that will not need any strings to be pulled to get the emmisions to pass and will not shake your teeth.It will be very easy to tune also.
I have many dyno sheets in my hand where it has made 390-400 rwhp and real nice torque in the 370's range w/o headers.That is pretty good in my book for a car that sounds stock and looks stock.
Current cam - LPE LS1 Camshafts 350-383-427 207/220 .571/.578 w 1.7 rocker 118.5 CL
:usa:
:usa:
I looked at this cam also. It looked like it had a lot of exhaust for a header/low restriction exhaust that I have. This cam would definitely be a sleeper type cam.
D.J.
Yes it does.
If you read John Lingenfelters book..It will shed a little light!
:ity:
Andy
Update-09-04-05
I spent the day dis-assembling the car and cleaning for a full 8 hours....Wow that is some work,BUT WELL WORTH IT.I got more accomplished today than expected,You can do that when you have no interuptions and all the parts for the job.I started off dynoing the car before I put it on the rack,It amazed me with a full 307 rwhp and 307 rwt.
I will post pics of the dyno sheet tommorow with both results of OLD versus NEW
Here are a few pics of todays progress.
NEW PARTS AND CLEAN CAR-
Discussion Starter · #9 ·
No way on Headers
For the sake of keeping it easy,I chose not to do headers,Also there will be no reason to remove codes etc. so that it will pass emmisions.I am not trying to break any records here,so I have decided just keep it simple. :thumb:
Nice job on the cleaning, Andy!! :jammin:
Discussion Starter · #11 ·
Newest pics
I have decided to drive it for a few miles(100-200miles)before dynoing it.Look like I should hit the dyno sometime tommorow.
Here are a few pics finished and running.
Discussion Starter · #14 ·
Clean!
I do not like to get dirty when I put them back together.I am going to try to get it in the paint shop to get the final stage done this week.Should be on the dyno today...Got some miles on her last night.
:guiness:
Are you going to put a partition in that car :lol: Just messin' with you. You can come clean my engine if you want.
Discussion Starter · #17 ·
We are all done with the hp mods
Here are the results of the car beating our expected numbers.
:thumb: LPE GT2-3 cam and heads come through again. :yeadog:
Very nice Andy.
That car could be the definition of "Less is more".
Pat :thumb:
Discussion Starter · #19 ·
Less can be more
My day to day experience has paid off here,I had a budget in mind,met it all the way through...No suprises here.Lpe does a wonderful job on designing systems that work...I just added a little in the middle. :guiness:
:thumb: :thumb: Nice job man...
Chris
1 - 20 of 64 Posts
