for those who don't use PIAA...what do you use?
Ok...where do fog lamps go on a Z06??? I have a VaraRam and do not want to mess up incoming airflow.
I too i'm looking getting a set of PIAA's but run with a Blackwing, however am concerning moving to a Varram set-up.
Where do you guys mount the aftermarket on/off switch. i do not to install on the line as park lights/running lights.
Do these Piaa's make much of a lighting difference? I'm during running with upgraded bulbs- the difference is noticeable, but the upgraded high beam seems like they out of adjustment. They are not very usable, unless it's extremely dark or in a narrow road. It almost seems like they diffuse to much on high beam only.
Any thoughts?
John
anyone?
Most do not use the aftermarket switch. They order an OEM C5 fog light switch and mount it in the stock position. This is much cleaner and neater.
