1 - 11 of 11 Posts
Has anyone done away with the fixed mast and installed a power antenna?
If so, how difficult was the installation?
If you're going to order the OEM parts, please check with our newest forum sponsor, Fairway Chevrolet, who will give you a MONSTER DISCOUNT on OEM parts! Check 'em out !
Let us know how the install goes :)
Vince
I'm switching to the 8" antenna and using the original to do some fishing with...:lol: :lol:
I'm sure our forum supporters, corvetteseller and fairway chevrolet will help get you your OEM parts :)
Just finished putting one on mine. Not too difficult.
You also need 2 bolts to mount the antenna to the bracket and 3 pieces of wire, each 12" long to do the wiring.
The bolts are $4 each. Probably get them for .50 at a hardware store.
Allow more than 1 hour.
Dave
I didn't completelydo away with the fixed mast, but I did go with the "Shorty" mast from Jake Delaney (Corvette Concepts). I'll try to get a photo up soon. Had three different chicks say it looks "Sexy". Sounds like a good reason to make the change:sneaky: :sneaky: :yeadog:
Joe:D :D :D :D
I like the idea of a power antenna... but would like it to only raise when on radio. Is there a way to wire it in to do that? I noticed that the article "got around" that by putting in an override switch that kept it from raising... but this is not an elegant solution.
Maybe I will have to change out the head unit to get an antenna power lead that works.
How does the power antenna on the coupe/vert that came with it work? always raise when the unit is on?
1 - 11 of 11 Posts
