I need an English interpretation of the follow rule in my efforts to reduce weight:
TCS page 7, 2005 GCS page 405:
b. Air Conditioners:
1. The factory and/or aftermarket air conditioning system may be removed, provided that at least the following items associated with the system are also removed: compressor, condenser, H.D. radiator, H.D. springs/sway bars, H.D. shocks, larger tires, engine and transmission coolers and cooling fans. All duct work, wiring, Freon lines, valves, evaporators, dryers, and dash controls may remain. If the air conditioning compressor is and integral part of the drive system, the compressor may be retained and disabled.
What does H.D. stand for? How are the springs/sway bars, shocks, larger tires related to the air conditioner?
If all duct work, wiring, lines, valves, dash controls, etc. may remain, does that not imply that it also could be removed?
