Slight correction Bleubyu, once you take exit ten you will turn right at the SECOND light, not the first. After you turn right, you will then turn right at the first stoplight you encounter. Criswell will be on the left.
On 2001-06-01 10:23, BLEUBYU spewed forth this drivel:
I believe you take a right at the first traffic light once you are off the ramp. You will go about 1 block to the dealership.
