Thanks I appreciate the reply. I am certain the front leg had 3 washers & the rear legs 0. I just dont know which had 2. I'm going in for an alignment soon as i get back together so it should not be a big deal.ELF Z06 said:The Washer are of two different types. Some have a rubber insert to keep it on the bolt as you loosen the a arm but not pull the bolt out. The other type is a simple washer(plain). These are part of the alignment. They will affect camber and also caster to some degree. From what I've seen on our car both bolts on each leg of the arm use the same number of washers. I'm afraid I can't tell the quantity on each leg. So if you have washers laying around and only one leg unbolted space them equal.
I hope this helps at least a little.
