1 - 2 of 2 Posts
"service traction control" has been popping up here lately...about every time I drive it. I am getting codes:
DTC P1125 - Accelerator Pedal Position (APP) System
P1286 APP Sensor 3 Circuit Performance
C1278 TCS Temporarily Inhibited By PCM
When this happens I get a "reduced engine power" on the display too. The car is almost dangerous to drive since it doesn't want to accelerate at all. Normally when I re-start later it works fine (though I have to manually clear out the check engine light).
Any thoughts on what is causing this? I am assuming it has something do do with the drive by wire system but don't know where to start???? Any help would be much appreciated.
Do a search on "service traction control" and will get lots of idea's.
It the BCM is going bad the fix is expensive if not under warranty. :blush:
1 - 2 of 2 Posts
