It will only give you erronious speedo readings....but who cares what the speedo says in an autocross. BTW putting 17's on the rear will raise your effective rear end ratio from 3.42 to around 3.56. Should help the acceleration but may not be legal in Super Stock. But may be in other classes. If you're keeping the 17's on the rear for street use you may want to reprogramm the computer so the reading is accurate. But then if you run the 18"s again it will be off until you reprogram it. Can't have your cake and eat it to.
