The street version of the C5R is all aluminum
and it is a wet sump version. Beefed up bottom end.
KG3SR7 Street Race Engine
7.0L LS1
585 BHP
$26,995
Race Cylinder Case
Stage III CNC Ported Heads
Crank, Rod, Pistons
Katech Camshaft
PCM/Harness
The package price on this engine is an estimate and can vary dramatically dependent upon customer specific requirements.
The core charge does not apply in this case because the cylinder case is not a production case. We will however apply a credit if a core is supplied.
Options
If you purchase a crate engine you may need to buy these components
Headers
4 into 1 $ 1,100
PCM
GM Upgrade or Reflash
$ 529
Harness
Katech
$ 770
Build Your Own
If you want to build your own LS1, we have the components you'll need here ==> LS1 Cylinder Heads and Packages
LS1 Components
Katech can develop an LS1 engine package for your program's requirements or specific application. Contact us for more information.
Jim Hall
