My oil life % has been on 52% for a long time. I think its broke. I went to change the oil thinking there was a glitch in the system. It didnt change anything.
Did you reset the oil life indicator after changing the oil?
This sounds like you believe just changing the oil resets the "Oil Life Remaining" indicator. I hope you know that YOU have to actually reset it.
bobby778...
I did a cross country trip (NY to NV and back) and averaged over 70MPH. Most of the Interstate travel I had the cruise set at 90. I burned 1 quart at the 4000 mile mark and when I returned (about 5700 miles) the oil was still clear enough to see through and the DIC said 47% remaining. Each car is different so there is no telling what the % should be after a given number of miles or what color the oil should be either. I use the DIC exclusively when deciding when to change the oil. I generally go down to the 25% remaining figure before I change it.
Charlie
Banned
FWIW I'm one of those wasteful morons who changes his oil religiously every 3K miles. (I'm stuck in the '60's according to some here) :ity:
The DIC on my '03 (which I drove like I stole it) was usually around 65% at 3K miles. I just looked at my '04 (which I pamper) and with 2600 miles since the last oil change, it's at 76%.
