Well, today was the day I was both anticipating and a bit nervous about. What if my new baby didn't have the pony power it was supposed to?
First, let me say that John Sealock at Woodbridge Dynotech has completed set-up of his new shop, and it is a class act all the way. If you live in Northern Va, and you want to know how many mice are runnin on that treadmill under your hood, check them out. They also do a lot of serious performance tuning..
So here is the background info:
Mileage on Bleu - 1,100
Air Temp: 81 degrees
Humidity: 73 percent
Water temp: 198
Fuel: 93 Octane
Mods: Vortex cold air rammer and bridge.
Note: I did not baseline this car as I literally drove it straight back from a Museum Delivery to Corvettes at Carlisle where BPP offered to install their system at a substantially reduced price providing I left the EB with them for several hours - it drew a LOT of attention!
So, the most admittedly unscientific method I could come up with is to find all the '02 stock Dynojet best runs, add them together, then average them out. The rwhp range was 337 to 356 and the average came out to 349.2 for the '02s. This would "appear reasonable" since this number divided by .85 is almost 411 crank h/p.
I did three pulls, which each pull being stronger than the preceding one (the car was definitely "learning"). The last pull was 5.4 rwhp higher than pull number 1. My last pull was 357.5 rwh/p (which equates to 420.5 crank h/p) and 350.3 rear wheel torque (which equates to 412 ft/lbs engine torque). :cheers:
I was very pleased, especially considering that there was definitely some detonation (noise) in the 6100 rpm range indicating that timing was being backed off. Also, the dyno shop manager (who has tested numerous LS-1 and LS-6 engined cars) said that I will need at least 5 times as much mileage on my "green engine" before it is broken in completely. He feels that as is, my car with detonation eliminated on a broken in engine should be worth 8-10 additional ponies.
Conclusions:
The '02s are making advertised power, in fact averaging a few horsies above rated power of 405.
The Vortex is probably worth at this point, about 8 rear wheel, or 9.5 crank h/p on my car - at this point, while sitting on the rollers with a fan blowing on the front of the car. This is probably a pretty realistic number given that the '02 stock air box is approximately 400% larger than the stock '01 box. As I have said before, hype notwithstanding, I don't think it is realistic to expect huge gains from any of these cold air systems which are essentially enlarged cold air tubes capped with K&N type filters which are placed to ingest cooler air. Intake gains may be futher improved with the addition of headers, but of course that will not be known.
I will be back next Spring to retest once I have chosen and installed headers, and the motor has a few more miles on it. I think it is realistic to hope for power in the 435 range at that point.
I will post the actual graphs once I have a jpeg...
I love the car - I'm keepin her!!
Water temp: 198
Fuel: 93 Octane
Conclusions:
