· Registered
Ok... I ordered a Corsa X-pipe expecting it to connect at one end to my new TPIS headers, and the other end to the cat-back. But it doesn't. I put a post up in the "products" section, looking for such a pipe, and someone replied that Bassani makes what I'm looking for.
I checked out the CF Mall, and there is a Bassani X-pipe for $259. Is this the right one? It's an off-road, no-cats pipe right? Sounds kinda cheap considering that's not much more than I paid for the Corsa, and the Corsa has a lot less pipe in it than one that goes the whole length of the car...
· Registered
Jim,
Sorry I don't have an answer, but probably one of the easiest things to do would be to call one of the supporting vendors. I'm sure they can answer all of your questions. /phpBB/images/smiles/icon_smile.gif
· Registered
Bassani makes 2 pipes. 1 is from the Cats back to the over axel flange. The other is an "OFF ROAD/Racing" only Cat eliminator from a long tube header position to the over axel flange. You will need "dummy" plugs for the CAT sensors if you eliminate the CATS.
