TCSZ06 said:
I am also looking for rear drag radials. What brands of tires are you looking at? I've spent a few hours on tirerack.com and still haven't decided yet.
It depends what how you're going to use it, If you're going to have on spare rims for track use only then Nothing beats the BFGs for hooking, but they will only go about 5k miles til the tread completely goes away which still makes them perfect track tires, just make sure to only go about 1-2k miles so you dont get to the wire and have a blow out, but before the tread goes away IT IS AS GOOD AS YOUR F1s on the wet, if you do get them bold, they we'll be unbelievable dangerous in the wet, and I mean undrivable on high waters, if it wasn't for our Stability control Im sure you would have to call a tow truck to get it home(yea its that bad). But if you are looking to drive them on the street as well, you can get the NITTOs, they're not half as sticky as the BFGs but they'll have a longer tread life which means they'll be better for everyday driving as well.
Recap, if you're serious about getting to hook on the track, get the BFGs as spares, although you're buying more tires now, you'll save money on the long run. If you still want DRs but want to drive them on the street, then Nittos is problably what you want if you dont want to replace your tires 5k miles, :cheers:
