1 - 1 of 1 Posts
When you're behind the wheel of your Corvette, the only things your hands should be doing are shifting gears, holding the wheel, and feeling the wind rush by outside. The C2 C3 C4 C5 C6 C7 Corvette 1963-2014+ Bluetooth FM Transmitter / MP3 Player / Radio / USB Charger Car Plug In Kit handles literally everything else for you.
After pairing your smartphone with it, the Bluetooth FM transmitter transmits audio files from your smartphone to your Corvette's stereo, answers phone calls hands free, and all the while the CVC technology creates dual sound with background noise, like wind, suppressed.
A 1.44 inch display screen shows the current voltage of your Corvette's storage battery, the names of songs, and caller ID. Other features of the Corvette FM Transmitter include USB car charger capabilities with automatic adjustment in output power for easily switching between devices. This universal design allows for the transmitter to handle a wide range of mobile devices, and it works by using unused FM frequencies to wirelessly transmit the data from phone to speaker.
It installs with a simple Bluetooth pair, and each product includes: 1 Bluetooth transmitter, 1 user manual, and 1 audio cable (1 M). Goose neck provides easy, stable adjustment where ever you need it.
Specifications:
Bluetooth Version: V3.0 + EDR;
Effective Bluetooth Range: 10 meters;
FM Frequency: 87.5MHz - 108.0MHZ;
Working Voltage: 10V~24V;
Audio Input/Output: 3.5mm audio interface;
USB Charging Port: 5V/2.1A.
Supported File Types: FLAC; WAV; MP3; WMA;
3.5 mm Audio Port Supports AUX Input/Output
Available in silver and blue.
Now Available for $29.99
Click Here To Order:
https://www.corvettemods.com/C2-C3-C4-C5-C6-C7-Corvette-1963-2014-Bluetooth-FM-Transmitter-MP3-Player-Radio-USB-Charger--Car-Plugin-Kit_p_15994.html
1 - 1 of 1 Posts
