When replacing the master cylinder, obviously you're going to get air in the lines. I've always heard that introducing air into the line going into the ABS unit is bad, but not sure why. Is there anything special I need to do (i.e. Tech II bleed) or can I just bleed the crap out of it to get the air past the ABS unit? Thanks.
