I'm having trouble installing the B-K Lap Belt Mount kit. Does anyone have the instructions? Can't figure out how the outside mount hooks to the seat belt retractor.
Any help would be appreciated.
Thanks.
David. Send me your email address(to [email protected]) and I will send you some pics of the install. :z:
To install out board BK clip in mount:
- unblolt front seat bolts
- slide seat forward and unblot rear seat bolts
- using button on back of seat, bring seat back forward
- line tunnel with towel to prevent any scratches
- tilt seat inward, side to side
- be aware of seat electrical connections on bottom of seat
NOTE: it is not necessary to remove seat, but you can if you wish
- remove rocker panel surround by carefully pulling it off
- remove B pillar surround
- unbolt seat belt reel from rocker panel
- install OEM seat belt reel inside of BK bracket
NOTE: larger bracket goes on drivers side
- install BK bracket and seat belt reel using OEM bolt
- enlarge seat belt relief slot by removing 3/16" from upper lip in B pillar surround using dremel tool
- reinstall B pillar surround
- reinstall rocker panel surround
- tilt seat out of car
- install inboard BK mount
- reinstall seat
Thanks Baron and DJWorm for the B-K instructions.
I really appreciate both of you.
David
