There is a special plug and play wiring harness offered by GM that you will need. I have the info somewhere and will try to find it. Other than that, the install should be pretty simple
Hi there,
Frank is on the money, as you plug in the wiring at the base of the i/p, passenger side, and run the wiring through the holders in the body, to the rear storage area.
The hardest thing really is to bond and rivet the changer bracket to the rear tub.
Best to you, c4c5
We’re a forum community dedicated to the Chevy Z06 Corvette. Come check out discussions on performance, specifications, modifications, purchasing, maintenance and more!
