1 - 10 of 10 Posts
Was running a 1/4 tonight.............
Had the AH/TC light up, and limited spin..............
So, here's the question..........
I ( yesterday) set the system in "Comp", mode...........
I assumed............that when I set it, it would stay set........in that mode.
Does it revert BACK to AH/TC, when the engine is shut off???..........
Like, do i have to re-set for COMP mode every time I kill the engine........or is there a specific time period in which it will revert on it's own automatically?????
Or, have I purchased "Christines", sister?????..............:eek: :eek: :eek:
It does not say set when you turn off the key, I wish there was an option in the DIC.
It defaults with AH/TC on.
You must manually disable or set to COMP mode each time.
No override on this.
Don
UHmmmmmmm
Thanks guy's,,,,,,,
This little lack of knowledge on my part, screwed my run up..........
Must be RE SET each time you kill the engine..........what a crock.
This has to be a saftey issue...................can you spell L_I_A_B_I_L_I_T_Y.............boyeez', n' Gurrlllss:roll: :roll:
it goes back every time ignition turns off. i have read some where there is some kind of competition mode bypass so everytime you start the engine you are in comp. mode. may have been exit 28.
HIthere,
Yes, its a default. Always on, when you turn the key on.
You will just have to shut it off.
Besttoyou, c4c5:z:hammersgotacoffee
Thanks for the replies
Now I know......................It's got a default..............
And running it without resetting it was a myfault,,,,,,,,,:D
There's a site that sells a gizmo that puts the system into COMP mode automatically on restart. Can't remember the site name.
1 - 10 of 10 Posts
