1 - 8 of 8 Posts
Took a look at the battery......hooked up a 4 Amp trickle charger to it.
It registered 4 Amps, and then within 5 minutes went to 1.5...............
Don't think this is normal........IF the battery was UP, it should have not moved off of the 4 Amp mark.........right, wrong?????
The amperage from the charger will decrease as the battery becomes charged. When fully charged, the amperage will probably be close to 0.0.
CP
Thanks.............I guess since it went DOWN, that means the batt is almost at full charge 1.5.............
Will leave on overnight.............
See if this stops the display error.........:)
Its ok
Yep,
CP is correct on this, and the AGM battery will do this moreso than a standard lead acid battery.
Let us know how you make out, c4c5
wELL.....
LEFT TRICKLER ON OVERNIGHT.....AND IT REALLY DID NOT MOVE OFF OF THE 1.5 AMP AREA.......WAS SURPRISED THAT IT DIDN'T GO TO 0...........sorry......(caps)......what do you think???/
Ok, or maybe a bad cell??:-?
HI,
IT should never go to 0, as the charger will always supply juice. Now, whether the battery takes it, thats another story.
Best, c4c5
G
Also due to some electronics in the car are always drawing battery current so charger will never go to flat zero.
1.4 amp show battery is close to being fully charged.
Well......tried it out
Started the car a few minutes ago..............NO fault signal showed.........
We'll see if charging it fully, did/will do the trick.......thanks for your help!!!!!:)
1 - 8 of 8 Posts
