C4C5 HELP! This is different from the last clutch posting. This time I drove my Z just going out the drive to town, and the clutch felt like some one had adjusted the system up so much that the clutch would not totally disengage?:-? I had not driven it in nearly a week, then all seemed just fine. And after driving the car several miles I could not get the clutch completely release. The car would pull itself with the clutch hard on the floor even at idle or a little above and near impossible to shift gears without trying to match engine speed (shift with no clutch-up or down shift). Even on the way home I got stuck at a stop light and had to shut down the engine put it in gear, because it dragged the engine down so much it stalled, and then start the engine and go when the light changed. Got it home and it's parked till??? /phpBB/images/smiles/icon_frown.gif /phpBB/images/smiles/icon_flaming.gif
Where do you think the problem lies at?? /phpBB/images/smiles/icon_confused.gif Thanks for your technical help as always...ZO6Bill
