Hi All,
I in the process of putting together a mid engine chassis using a C5 suspension and I need some help. I’ve got the front and rear C5 suspension assemblies but as the upper A-Arms are not mounted the original geometry is a bit of a mystery.
With that does anyone have detailed drawings of this suspension or as an alternative do you know:
Are lower A-Arm pivot point parallel to the ground on both ends?
Instant Center/Roll Center height?
Caster
Bump Steer Numbers
Stock corner weights and stock spring rate
Many thanks!
Sorry I can't help you with the info you need. Hopefully someone will see this post and chime in with the info. :cheers:
Thanks for the update,,, these are some good numbers. I do have an additional questions if I might. I'm tempted to get a copy of the SAE SP-1282 document,,,, but maybe you've seen it already. If so,,,, do there have any additional information in regards to the suspension?????
Thanks again!
