Thanks for the reply. I will troubleshoot that info. Sorry, I did not give the whole story of the problem from the get go. Anyway, I first noticed the problem when driving the car. I heard the door actuators cycle a couple of times and said what the heck is that? The problem went away and I did not give it much thought. Then it happened again after several months. Same story it went away and I left it at that. Then about a month ago the problem resurfaced again while driving. This time it was more severe, the door actuators kept cycling in rapid succession and would not stop. I decided to drive the car home before something worse happens and leaves me stranded etc... Before I reached my home the cycling stopped. That's about the time when I started to noticed the car was unlocking and locking the doors in the garage with no ignition on etc.. I thought it was just when driving the car. Then a few days later it would happen again and so on. To the point of running the battery dead.
I'm going to take the car out on a test drive without the key fob and see if I can duplicate the problem. Then take a look inside the doors. I've been inside the doors before. About 3 or 4 years ago to replace bad window regulators.
