1 - 20 of 28 Posts
OK,
I'm back in business! Just bought a 2002 Z06. It's stock and in great shape. Need to change that...el pronto!! I salvaged my Kirban short shifter. I'll be replaceing all the fluids and hopefully do the LS1 edit to take the 1-4 shift crap off. I loved the old FLP header package with the V band clamps for the high flow cats. But they aren't around any more. I'm looking for Long tube header suggestions. Installation & perfomance. Thanks.
OK,
Welcome :z: It's Always Good to be back in the saddle again :D
OK,
LG is a great fit with good hp gains and so is American Racing headers. Both proven at the track. There is also Kooks that I have no real knowledge of but supposed to be good. Just suggestions.
I run LG myself.
Glad to hear you are back in the saddle again. If I had to do it again, my first choice for long tube headers would be ARH headers....made in the U.S.A., not some chinese knock off. Easy installation and great quality is a plus.
Z06 Tech Advisor
You have the only true American sports car so why not use American made mods ?
Look at Stainless Works,
they have been making headers for the Corvettes in the ole USA for decades and use good quality stainless steel
Else compare to ARH,
LG is made outside the USA for high profit margins, lower quality, workmanship and fit.
OK,
If I was buying headers - ARH all the way!
Also - if you are doinig the install yourself, I've heard the ARH are much easier than Kooks.
Discussion Starter #7
Wow, I never gave a thought to headers being made outside of the U.S.! I'm curious, 1 3/4" or 1 7/8" headers? I'm thinking of doing a cam in the future.
Z06 Tech Advisor
1 7/8 primaries with stock valve and cylinder sizes will reduce low to mid torque so
the 1 3/4" will be fine
Better is also add a true X-pipe close to engine which will better exhaust pulses and help extract all exhaust from cylinders
Yep some overpriced headers come from cheap labor in Mexico or China
Keep in mind some of these headers are too long forcing all 02 sensors and Cats further downstream and cause AFR issue
Use a pro who knows how to tune for them to reduce chances of failing EPA I/M or tailpipe smog tests
Do not forget to install heat socks over sparkplug wires and any place headers are too close to harness wiring to protect them from that heat
I have had Dynatech LT's and am currently running ARH LT's. Both made here in the USA and both all stainless steel. The ARH's are the easiest header install I've ever done on any car! Highly recommended! :yeadog:
Jimbo
Discussion Starter #10
Thanks everyone. Mike, thanks for reminding me of the socks and pointing out the X pipe placement. I think I'm down to Stainless Steel Works or ARH. But I could change me mind over a couple of beers! Thanks again everyone.
bump
I run ceramic coated SLP LT headers with HFC/Xpipe to stock ti's. headers are 409 but the rest of the system is 304.
Once the headers were installed, fit is perfect. headers aren't as high quality SS as borla or ARH(409 vs 304) but system is 500 cheaper and they're lifetime warranty.
fitting headers went through top and took some work removing the generator/bracket and a prybar to convince the engine to either side. pass was a lot easier than drivers.
For what it is worth, my set of Kooks (1 3/4") stainless steel were installed by Lingenfelder in late 2005. I have never had an issue with them and I have tracked this car from Spring of 2005 to the present. Food for thought...
My LG's were made by Borla for LGM. Not outside the U.S. Unless they changed since I got mine. Very good fit and quality. I got the LG Pros, not their cheaper line.
Z06 Tech Advisor
All LG headers are made outside the USA
C5 were from Mexico
C6 are from China
Most people do not even own a OBD scanner, know how to use one or what scanner is telling them and have no idea a weld(s) has cracked and sucking air in to effect what 02 sensors report
As to fit I have seen some where the flange was not even welded to primaries at the proper angle.
Just last week saw one that the front right 02 bung weld was cracked causing the PCM to see huge left/right engine fuel trims off balance and C6 Z06 owner wondering why GM warranty would not cover repairs.
For cheap labor they should sell for 25 percent of LG prices :(
C5 were from Mexico
C6 are from China
Maybe now they are made in Mexico. But I got mine in '04 and they were using Borla to make their headers. All my documetation and instructions and parts list was from Borla.
I got mine in 2006 (LG Pros by Borla) and I personally inspected every inch of them, and all of the welds were perfect and even ground down on the inside of the flange to smooth out the welds. These headers and x-pipe made by Borla at the time, was a quality product ...not now with items being made in China for LG.
If I had to do it again today....ARH or Stainless Works.
I got Kooks this summer and a dyno along with it. I have run 2 DEs' and had no problems. Still running stock Z titanium mufflers since I love the sound. I did notice a more racy sound at WOT. With the dyno it did away with the 1 to 4 shift.
1 - 20 of 28 Posts
