1 - 20 of 33 Posts
there's a guy over on ferrarichat claiming that a C5 Z51 has a higher top speed than a Z06. he sites better rear window airo and gearing as the reason. i call BS. i was under the impression that until the C6 came out, the only vette with a higher top speed was the ZR1.
can someone confirm this?
here is the original link
Sorry, but I think he's correct.
He's 100% correct. The Z06 tops out at 173mph at redline in 5th gear, the coupe has taller gearing in the tranny and can hit 180mph or so. The coupe also does have a better CD due to the fastback rear glass. The better aero is why the C5R uses the fastback rear glass and not the Z06 notchback body style. :yeadog:
wow, didn't know that. amazing that gearing and airo can make up for a 60HP difference. thanks!
The diffence is gearing. Sure there is a aero advantage - but I am doubting it has the effect of running into a wall at 174mph, preventing a taller gearded Z from running to 180mph.
Higher ratio would have the C5 Z rolling to the same speed.
The one time I ran up to the redline in 5th, Ihit the rev limiter - the car still had go. And I run a meak 385hp '01.. :p
405hp Z's with Coupe 5 speed tranny would surely be able to pull 180mph in 5th.
Haha - I just readthe thread.
C5 Coupe - :lol: - sure he has better "top end" - but imagine how long it's going to take him to catch up and pass you from 10 cars back and only being 5mph quicker... Some people.. :p
Discussion Starter · #13 ·
:lol: i know! i followed up by giving the mosler example: yea, a Z06 is "faster top end" than a photon, but i wouldn't even be able to SEE his taillights by the time i got there! :lol: ah well, he'll learn...
z06_23_45 said:
You're right, but that's the reason they didn't go with the notchback. It is what is going to give the Z the nearly 200mph top speed.
I have to disagree until some engineering boffin provides proof that the FRC can't reach 200mph with 500hp on tap.
With friendly gearing and 500hp on tap I am willing to bet an FRC could run to 200mph.
Yes, the C5 hatchback can reach a slightly higher top end speed. For all out top speed, it's more a function of the gearing than the body shape. The .01 or .02 higher drag factor is not going to have as big an impact on the top speed as the gearing does at the speeds that are in play here.
However, the time it takes the hatchback to get that top speed and the z06 get to its top speed, which is only a few mph, the Z06 will be well ahead and it would require a very lengthy straight stretch at flatout speed for it to ever catch the Z06.
I sort of disagree ... AERODYNAMICS -- and gearing make all the difference in the world. And John Lingenfelter used a hatchback vs. FRC for the stage II TT project for magazines because with the hatchback it could hit 230+ and be more stable. As far as with enough horsepower anything will go fast I don't agree sort of...(if you put a rocket on anything it will move out) however Have you ever seen a CASA 212 or Skyvan fly... Thank God for strong turbo props and enough wing or these things wouldn't move. They do not go as fast though. Put the same engines on an MU2 and you have some speed.
Chris
The horsepower requirement goes up as the cube of the speed. So IF you could go 180 mph with 400 HP then the HP required to go 200 mph would be 548.
200mph / 180mph = 1.111
1.111 ^ 3 = 1.372
400HP * 1.372 = 548.7HP
There's you mathematical "proof" of how much HP is required to go 200 mph.
However, no Corvette can go 180 mph with only 400 HP, so it would require even MORE than 548 HP to go 200 mph. 200 mph is out of reach for any GM factory production car no matter how it's geared, even the C6 Z06.
Rod
1.111 ^ 3 = 1.372
Rod
Your "proof" needs a little work. All Corvette body styles can easily go 180mph with 400hp if geared correctly.
1.111 ^ 3 = 1.372
G.M. must be using the new math everyone was talking about a few years ago. They claim the new 06Z06 will run close to 200. What gives. Isn't it referenced to the CD of the car? A 800 HP UPS truck couldn't run 200MPH. Is the point of reference in you formula 400HP requirement to achieve 180MPH? Would the new Z's aero number have anything to do with it. As in it may not take as much HP/TQ in a new Z to run a higher top speed than say a 2004 Coupe.
D.J.
1 - 20 of 33 Posts
