1 - 12 of 12 Posts
Well it happened this way, I pulled my car out of the garage to wash it then take her for a spin. After washing I started her up, went to push in the clutch, the peddle went to the floor with zero resistance, without disengaging the clutch and stayed there. After checking to see if the push rod had become disconnected, which it hadn't, I looked for fluid loss at the master cylinder and under the car and found none.
Knowing this I called my local Chevy dealer, picked the service managers brain, then called a local performance shop to get their opinion, I've pretty well narrowed it down to the master cylinder. Of course I could be wrong and after replacing the master cylinder, if that doesn't cure the situation and I have to replace the slave, I'll know I won't have a week link anywhere.
I figure I can replace the master myself, I just haven't done one in a long time. If it turns out to be the slave, I'll have to have that done by a shop as I don't have the means to pull the transmission.
Any pointers and or special tools needed would be greatly appreciated.
Z06 Tech Advisor
The master for the C6 is junk, cheaper design then the C5 had
Common to fail is the tip of plunger on the shaft in the master pops off
You might want to take master apart and if same problem then reattach and seal so it cannot come off again and put back together.
If not using a hoist best is take off inner fender off left front so then real easy to pull hose apart and get the bolts off master to firewall
Remember you need a tool to get hose coupler apart of master to slave
just Google Tick Performance Adjustable Clutch Master Cylinder
just installed a Tick on mine after my clutch pedal stuck to the floor. i love it, a little firmer but very consistent. it took me a little over 3 hours to complete the job. youll need a good tool selection and patience. just make sure you bleed it good before reinstalling the quick disconnect. if you have any questions let me know.
Thanks all for the input, I'm on a mission!
Just take your time. You may want to take out the drivers seat. I didn't, but I'm only 185 lbs. You have to climb under the dash...upside down. :lol:
I installed the tick master cylinder and it did take some time. My problem is that I have had no luck with the "quick connect" to my slave cylinder. Do you any advice? I am not a weak guy and although I'm squeezing with all I have with some channel locks, it will not click into place.
1 - 12 of 12 Posts
