2006 Corvette Z06 (Track Build)
SERIOUS INQUIRIES ONLY
(Not desperate or in need to get rid of)
Contact : 4zero7-nine0two-8fiveone1
  • Build is 90-95% complete
  • More photos / videos upon request + links to parts
šŸ’„MotoršŸ’„
Builder: Central Florida Machine & Speed, Orlando.
Engine spec by CompCam Engineer from CompCam
All internal parts on the engine are new and race grade parts (ls7 oem block and heads)
-DYNO TUNED MPT performance (safe not lean) 13:1 factory
Approx: 615hp / 600 torque - (to the ground NOT crank)
ā—Car has not been raced since buildā—
šŸ’„Under The HoodšŸ’„
-Kook Headers Ceramic Coated Headers Exhaust (cat-delete)
-Moroso Vented Valve Covers
-Mechman Alternator
-TurnOne Power Steering Pump
-ATI Super Damper ATI
-Katech Oil Pump KAT-A5069-LS7 - High Capacity Scavenge, Ported Oil Pump (katechengines.com)
-Oil Sump and Oil Tank Mods by Aviad. Z06/LS7 OEM
-DeWitts Radiator
-LSxR 102 Intake FAST LSXR LS7 102mm Intake Manifold
-Fast Fuel Rail FAST LSXR LS3/LS7/L76/L99 Billet Fuel Rail Kit (texas-speed.com)
-Nick Williams Performance Throttle Body Nick Williams Performance Throttle Body 103mm Drive by Wire (LS1, LS2, LS3, LS7)
-Lingenfelter Air Intake System Lingenfelter C6 Z06 LS7 Corvette High Flow Air Intake System
-Hinson Delrin Motor Mounts
-HP Ignition Cables
-AN Fittings
-SS Braided Tubing
-Heat Shield Covers\Wire Protection
šŸ’„TransmissionšŸ’„
  • Quarter Master Racing Clutch Kit: Optimum-RR GM LS Race Clutch Kit - 7.25"
  • MGW Shifter Kit MGW Aftermarket Racing Shifters
-Aluminum Driveshaft Eliminate Rubber Coupler
šŸ’„SuspensionšŸ’„
NOTE: This car has a TRUE 4 wheel independent suspension
-JRZ RS Pro 06-13 C6/ZO6/GS/ZR1 Corvette JRZ RS PRO Double Adjustable Club Sport Damper (xplosiveperformance.com) Front and Rear
-Eibach Coilover Springs
-T1 GM performance sway bar w/ adjustable buckle (front and back)
-SKF Racing Hubs SKF Racing Hubs - LG Motorsports
-CCW 18ā€ Monoblock Racing Wheels (front and rear) CCW Corsair C10 Forged Wheels
- Stoptech Brakes
- Rotor Cooling Kit
šŸ’„OtheršŸ’„
  • Brey-Krause Harness Mount Bar
  • 6 Point Harness Driver and Passenger
- Aero Body Kit (front lip painted not mounted)
- APR GT Wing APR GT-250 Corvette C6 71" Wing
- Body-Off Custom Axalta Paint. 5 coats of true pure black including painted trim to match
- Vented and custom painted hood (vents painted not installed)
