Will the C6Z's rear tires be compatible from an AH/TC/ABS standpoint with 275/30-19 front tires?
I'd like to run those rears with my Pirelli's up front so I can keep the same wheel package.
Based on experience with the C5 Z06; probably, if the tire diameter/circumference difference is NOT GREATER than >5%.
The difference between the 295/35/18 (stock C5Z06 rear and the 325/30/19 (stock C6 Z06) is Diameter Difference: 2.07%
IMO this is fine. Anything much more than 3.69 is unacceptable IMO
