A bigger cam will generally cause more oil consumption especially with a lot of overlap. I am running a 244/248/114 and eat about a quart every 1,000 miles. If I really run hard, I burn a quart in under 1,000 miles. Make sure you check the oil when the engine is cold and at least every other week if you are driving the car regularly. I run about 20 psi of oil pressure at idle and at operating temp and then another 10 psi per 1,000 rpms... I like to watch both oil temp and oil pressure when I'm on the road. Coolant temp is not as important as either oil pressure or temperature in terms of protecting the heart of the beast...Z06 Steve said:I got done with a cam swap now the low oil level light comes on.checked the oil level on full mark.could my 233/233 choppy cam give a false reading for the light to come on?
