1 - 8 of 8 Posts
If this is a repost mods can just delete this.
If not read on:
Camshaft Specs
Rocker-ratio intake: 1.80:1
Rocker-ratio exhaust: 1.80:1
Degrees Duration:
At camshaft: Intake: 0.331 in. Exhaust: 0.328 in.
At valve: Intake: 0.593 in. Exhaust: 0.588 in
LS7 General Specs
Engine type: Cam-in-block 90-degree V-8 Block configuration: Cast-aluminum with pressed-in cylinder sleeves and 6-bolt, forged-steel main bearing caps
Bore x Stroke (mm/in): 104.8x01.6/4.125x4.00
Displacement: 7.0L/427ci
Crankshaft: Forged steel
Connecting Rods: Forged titanium
Pistons: Cast aluminum
Compression Ratio: 11.0:1
Cylinder Heads: CNC-ported aluminum; 70cc chamber volume
Valve size, intake (mm/in): 56/2.20 (titanium)
Valve size, exhaust (mm/in): 41/1.61 (sodium-filled)
Camshaft: Hydraulic roller; 15 mm (.591 in) lift (intake and exhaust)
Rocker arms: 1.8:1; offset (intake only)
Air intake: Composite manifold with 90mm single-bore throttle body
Fuel: Premium required; 91-octane minimum
Horsepower: 500 (373 kW) @ 6,200 rpm
Torque (lb-ft): 475 (644 Nm) @ 4,800 rpm
Engine redline (rpm): 7,000
kingpin
KINGPIN said:
Camshaft Specs
Degrees Duration:
You did not post the duration, only the lift at the lobe, and the lift multiplied by the rocker-arm ratio.
Who is going to pay over $70K (base of $65,800) plus options plus tax and then tear the engine apart to put in a decent high performance cam and AFR 225 heads?!? :screwy: I also hear the exhaust sounds tame...more mod $$$$$$'s. :roll: I must be confused. :-?
Bob :blush:
You are. LS7 heads are much stronger than AFR225s. However, were emissions laws allow, many will probably add headers and change the cam. Eventually, some will change the intake. Prepared versions of the head will come out. And prepped shortblock, built to tighter tolerances and using forged pistons, will come out.
To some, a $70k Z06 is a financial stress. Or a factory hot rod that will pass emissions with 500hp. And to others it is a better platform to build on.
1 - 8 of 8 Posts
