I get so many requests for this, I finally just "scanned" the suckers. This assembly of a bolt, nut, and two washers replaces each of the 6 adjusters (4 front, 2 rear) on the C5. The factory offset adjusters will not push the lower a-arm out as far as these will. Every car is different, but you can usually get around -2.25 degrees in the front and about -1.75 in the rear. You can mix and match these with the OEM adjusters if you need less.
Nice. But sig too large.......15k max please :)
JC
