Can you run the CCW 505a 19x13 on the rear of a Z06 without tubbing or mini-tubbing? I know you can run the 19x11's on the rear, but the 19x13's would look more attractive (more dish) and hold at least a little more rubber out back.
Hype said:
Can you run the CCW 505a 19x13 on the rear of a Z06 without tubbing or mini-tubbing?.
No you can't. Call John at CCW he will give you a all the info you need.
Local: 386-258-0083
Toll Free: 1-888-577-0144
Fax: 386-248-0150
I have the 19x13 CCW 505 and you have to use a mini-tub. I ran both the 345 and 355 in the rear with no problems and an LPE mini-tub kit. Good Luck!
