So the CEL came on last night and I just retreived the codes. One code I could not find the description for. The car seems to be running fine, didn't notice any difference other then the light coming and staying on. Here are the codes. Any help since I have no idea what they mean would be appreciated. Not sure if I should take it in or not.
Thanks in advance
Aldo
99 HVAC - B0361H - left actuator feedback short to ground.
80 RADIO - U1064H - loss of communication with DCM
U1016H - loss of communication with PCM
U1096H - loss of communication with IPC
10 PCM - P1416HC - AIR system bank 1-B
60 IPC - U1016H - loss of communication with PCM
U1040H - loss of communication with TCS
U1088H - could not find the description of this code
U1176H - loss of communication with RFA
Most are History Codes (H), no telling how long ago they were set. Make sure you reset/clear the codes and see what happens.
The only code that shows is new is...
What does that affect?
