1 - 1 of 1 Posts
· Registered
The USB and 12v power outlets in my 2017 Z06 have no power. There doesn't seem to be any power to the fuse in the rear fuse block. I installed a new power retention relay (upstream from the 5A fuse for the power outlet). No success.
My next two steps are 1) direct wire to the fuse, by passing the power retention relay; and, 2) take the console apart to make sure the wiring is connected.
Any suggestions? Thank you
1 - 1 of 1 Posts
