Has anyone used the CG-Lock with their stock seat belt. It is designed to hold your hips into the seat. It is advertised in Grassroots Motorsports as SCCA National SOLO compliant. What do you think? :-?
I saw this item demonstrated at SEMA and it looked like a great, cheap simple solution. If you can't go to a full harness, I expect this would be a nice improvement on stock.
I haven't actually used one myself however.
You may already know this, but the stock belts already have this feature. While seated, pull the lap belt retractor all the way out, then feed it back in until it is really snug. It should lock there, holding the lap belt tight. The shoulder harness doesn't do this - too bad - but this should help.
