After driving around an hour, some in light rain, DIC flashed a message 'Charging System Fault, or Low maybe" I think, but as the engine power totally went to zero, I was too busy moving off the highway. Then, all of a sudden, power came back to normal. Dangerous as hell, especially on a freeway. Only code is the U1255 thing about serial buss loss, but that's a history one. Take it to the dealer? Everything looks fine, battery, alt., voltage, etc.
I've got to agree with Ronald. The battery is the most likely culprit. Have it checked for state of charge and also load test it. Loose connection someplace could also be the cause. Look for other problems AFTER you've determined the battery is working up to par.
Charlie
