took my beautiful pristine red C5 Z06 out for a spin today. I drive maybe 3000 miles per year. Total mileage about 62000. Did a major engine rebuild about 5 years ago at 55000 miles. Mild cam, head work, long tube headers, callaway air induction. She has been purring ever since. Today I got a check engine light and the following codes:
P0102 (MAF low frequency)
P0412 (air solenoid relay control circuit)
P0418 (air pump relay control circuit)
P0443 (?)
P0801 reverse solenoid
P0803 1-4 upshift solenoid
I have not had a code in 4 years and the car runs great. I cant get it into reverse witout tricking it by putting in first and rocking back and forth and then forcing it. I am wondering if this is not more electrical than mechanical with these parts because its strange that they all happened at the same time. Im a banker and not a wrench so I'm at a loss where to start. HELP!!!!!
2003 Quicksilver Z06
P0443 (?)
I think you got them all at once because they're related... Recommend take it to a reputable shop or Chevy dealer, who will likely replace solenoids (electromechanical valves). Should not be a major expense, but there's a lot of guys on here that know more than I do!
Super Moderator
Do you keep it on a battery tender? Not sure it would cause these issues, but low batteries are known to cause issues. It seems the less we drive them, the more issues they have.
  • Like
Reactions: lilesv
Totally agree! My '03 is sort of high mileage (150k) because I purchased it in Dec '02 as my daily driver. Thankfully, I've had very few problems with it.
