1 - 16 of 16 Posts
Here is a link to a thread at the CF site that Andy started. One can only speculate which air intake system he's talking about, but I think we can make a pretty good guess (this just after I switched to one :roll: ). Probably not a good idea to drive on dirt roads or down by the beach without pulling your filters and cleaning more often than not. :yeadog:
And just to think, we all are worried about sucking water up and hydrolocking. :roll: Damaged pistons/ring lands from dirt/sand/particulate passing thru the filters and thru the TB appear to be just as much as a potential hazard. :mad:
http://forums.corvetteforum.com/showthread.php?t=1088917&forum_id=1
Don
Don, thanks for the reminder. I don't drive on dirt roads or near sand, but you do need to clean the Vararam foam filters on a regular basis. I have the street filter and use a light coat of foam filter oil after cleaning and it works great, but I clean it every 2,000 miles. :thumb:
Bob :D
I've had my VR on for close to a year & a half. I clean the foam filter every other month or less! Knock wood, I only see some sand around the edges of where the filter sits (between the filter & the shroud). I don't worry about hydrlock, as I don't use my car as a row boat.
I guess I'm 1 of the lucky ones w/ a good filter seal...
Ron
Don
HI DON
I think there were other issues with this car but even if not he had a BLOWER on the engine and I'm not so sure the filter can handle that amount of forced air. I have never seen anything that bad ever. I don't think anyone will have that kind of problem if it is installed properly and maintained . I'm thinking lack of maintenance is a good part of the problem. If it had been maintained correctly wouldn't you think it would have been caught a loot sooner . I'm going to keep an eye on mine but honestly I'm am not that concerned but if I see even a hint of dirt it's gone . Till we meet again ( hopefully before the next HOOTER'S run)
Bob :cheers:
OLDGUY said:
HI DON
Bob :cheers:
Bob, I had a bottom feeder on my ride before the huffer was installed and replaced it with the BlackWing after seeing what got sucked into that thing.
I just read through the whole thread and was really amazed at the lack of understanding as demonstrated by most of the comments. :roll: Thankfully the members of this forum tend to form opinions more on fact than fiction.
Bottom line, I agree with OLDGUY. The guy was nuts to run a Vararam with a blower - he was just asking for trouble. I am willing to bet that the bulk of that material did not enter through the filter but around it, the design just will not stand up to forced induction. Just not a good idea. :NoNo:
As to the foam filter, if you are not willing to pull it every couple of months and do the maintenance then get a K&N filter.
WHAT HE SAID^ It seem like we have a lot of free thinkers
:thumb:
Bob :cheers:
And that about sums it up....
What exactly is the procedure for cleaning the filter. I know they have the kits to clean them, but I've never done it. Also, after reading the threads about excess oil getting into the MAF, I was a little partial about cleaning it.
On average, though, you should clean about how often?
I don't have a blower and my TB is always clean as a whistle when I check it. However, can somebody post the correct K&N Filter part number?
Thanks!
i use the k&n filter cleaning kit on my vararam fllter.it comes w/cleaner & filter oil.after reading this thread last nite, i pulled mine & cleaned it today.it's probably been 6 mo. since i did it.the throttle body was spotless & i was relieved!a little sand on the filter is all i found. :cheers:
1 - 16 of 16 Posts
